power inverter
power inverter
can someone tell me whats the biggest inverter i can get that plugs into a cig lighter? I cant hardwire and if caught i will be fired on the spot.
400 watt.
I am sure someone will come along with 500, 700 or some other BS, and while you might find an inverter with a 12v plug on it bigger than 400 watt, the wiring in the truck is not going to be able to carry enough juice to supply it and if it does you are running a huge risk of fire.
Originally Posted by firefighteremtb78
alright thanks...i guess there goes my microwave
DO NOT try to power it with a plug-in inverter....you will burn the tractor to the ground.
Forrest Gump was right....and some people literally strive to prove it.....everyday. Strive not to be one of "them".... And "lemmings" are a dime a dozen! Remember: The "truth WILL set you free"! If it doesn't "set you free"....."it will trap you in the cesspool of your own design". They lost my original "avatar"....oh well.
Wire a bigger inverter directly to your batteries. Be sure to use a fuse as close to the batteries as possible. I like the inverter to be 10% capacity higher then the microwave. Be sure to match the peak amperage requirements.
I have a 1500 watt inverter that I hooked up 4 gauge jumper cables to it. Cut off the clamps off one side and run the other side out the side door of your sleeper to the cat walk if you have a battery connection back there. Just don't leave it hooked up. Heat your food up then fold them up and put them back under your bunk. Of course this sucks in the rain and snow. I know from exp. But it saved me alot of money not having to eat at subway all the time lol P.S. the company I'm with now allows them. So I have one hardwired now.
Has everyone forgotten how to be COURTEOUS. If you've forgot, it means. respect for and consideration of others
use the microwave in the truck spot, they are usually clean, not guaranteed
Originally Posted by Mattangcobra
...run the other side out the side door of your sleeper to the cat walk if you have a battery connection back there.
