99 Volvo Problems
Old 03-30-2008, 10:36 AM
Default 99 Volvo Problems
Thinking of buying a 1999 Volvo 770. Has about 700000 on truck and 200000 on detroit 500 13 spd trans rebuild, paper work confirmed. Anyone have experience with this model volve. Have read front end problems also front axle weight problem. Not sure if fuel tanks are mounted forward or set back like newer Volvo. Any information appreciated.
Old 03-30-2008, 01:13 PM
The main problem I recall with them was premature wear on the front tires. I believe the problem can be solved by replacing the u-bolts on the drives.
Old 03-30-2008, 08:41 PM
They also had issues with the slave cylinder on the hydraulic clutch and the dashboard readout is prone to failure as well. That and the aforementioned steer axle issue are all that I remember when I worked on them back in 99.
I,ve always been impressed with the way the trucks rode and handled, the trucks I worked on were set up for flatbed and were equipped with Cummins engines (celect) and 10 speed trans. We ended up replacing the Solo self adjusting clutches early on as they didn't work.
Old 04-01-2008, 03:43 AM
2's Avatar
2
2 is offline
I've heard the body shop guys say that Volvo was the best on the road.
There is a fiberglass cap on steel, from around the top of the door on up.
You take it cheap, what's to motivate them to ever give you a raise?
Funny is Rookies telling pro's how to make good money running cheap.
Liberals - Relentless, Vile, Sniveling, Whining, Lying, Vitriolic Complainers.
