Advice on engines
Advice on engines
I'm looking for your input on what pre emmision motor is the one to look for i'm thinking 6NZ cat but all input is appreaciated. Thanks in advance.
cats are known for their pulling power, but not their fuel mileage and expensive to repair.
Detroits are known for their fuel mileage and for low cost maintenance. I know from experience with an EGR engine, they have PLENTY of torque and will outpull a lot of cats if tuned correctly. Cummins are in the middle. I got a detroit for low maint cost and good fuel mileage. at 850,000 miles, I don't use any oil at all. I had 4 galley plugs on my oil cooler leaking that we pulled and sealed up and also a broken oil dipstick tube. That was the extent of my oil leaks. My oil samples are showing this thing should run another 400K miles before anything major is needed. I would get a 12.7L detroit with NO hesitation. I'd consider the 6NZ but only after looking for a Cummins N14 redhead. Either way, I'd find the right guy to tune whatever you get.
Detroits are known for their fuel mileage and for low cost maintenance. I know from experience with an EGR engine, they have PLENTY of torque and will outpull a lot of cats if tuned correctly. Cummins are in the middle. I got a detroit for low maint cost and good fuel mileage. at 850,000 miles, I don't use any oil at all. I had 4 galley plugs on my oil cooler leaking that we pulled and sealed up and also a broken oil dipstick tube. That was the extent of my oil leaks. My oil samples are showing this thing should run another 400K miles before anything major is needed. I would get a 12.7L detroit with NO hesitation. I'd consider the 6NZ but only after looking for a Cummins N14 redhead. Either way, I'd find the right guy to tune whatever you get. but like said.. cant really go wrong with any of the pre egr motors. the question is. what kind of work are you doing?
I really enjoying reading you guys! Somebody once said;- There are no such thing as a stupid question, but some questions don't really have a straight answers, and is kinda tricky. IMHO you both did good!
The truck will be used to pull heavy loads 57500kg to 63500kg. I know i won't be going DPF since i'm already driving one and know what all the emmisions is all about already. What about the C-15 or the cummins with the EGR what are your suggestions going pre DPF?
Gearing then is a bigger deal to you than anything since that's equal to 125k to 140k at the high end there.
I'd be looking at something with at least 3.90 gears even getting up to 4.11 with an 18 SPD. Engine, a 6nz tuned to 600 HP. Or even a DD s60 tuned up. 2050 torque. You are talking a heavy haul rig really. Everything on that will scream major component upgrades IMO. From the frame all the way to ujoints to brakes.
I'd be looking at something with at least 3.90 gears even getting up to 4.11 with an 18 SPD. Engine, a 6nz tuned to 600 HP. Or even a DD s60 tuned up. 2050 torque. You are talking a heavy haul rig really. Everything on that will scream major component upgrades IMO. From the frame all the way to ujoints to brakes. if it was me, i'd do nothing else but a cat... single turbo cat. i'd just make sure it was a 18 speed with no lower then 3.91 gears. |
