Air Hose
Air Hose
Do any driver have those air hose that you can connect to truck air lines , if so do they produced enough air pressure to air a tire up on a trl or tractor. Thanks
You can do it but it's kind of a PITA because half the time the air pressure coming out of the line is too low. Then you need to go pump the brakes to get the air compressor to turn on.
It's good to have in case of an emergency though. |
