Block Heater Information?
The block heater on my truck looks fairly new, and I have used it twice so far, and man does it make cranking my Freightliner so much easier. The two part question I have is:
a. What all does the heater keep warm? b. Does it draw much juice from the electric outlet? (The reason for this question is, if it draws much juice then I would get a timer to cut on a couple of hours prior to me cranking it in the morning) Thanks in advance for your advice and wisdom.
Originally Posted by Maniac
It keeps the water (anti-freeeze) warm, and YES it will make a difference in your electric biil if you leave it plugged in a long time.
I find that 4 hours is all it takes to make it start nicely
Most of what people call a block heater is really a plug on the oil pan
Better re-check your facts, Cummins,Cat ,Detroit ALL use block heaters in the water jackets, in my 30 years only saw one truck with an oil pan heater, here in the states anyway. As far as how cold your anti-freeze is rated, doesn't have anything to do with starting the engine, and that would be for diesel or gas engines.
The block heater on my engine is located on the left side of the engine up towards the top of the engine. I have a 350 big cam Cummings.
The last time I used it, I know that my water temp was really warm when I first cranked it up. It really made a difference on an older engine cranking up. I just wasn't sure it it heated more than the water or not, and how much wattage it would pull.
Best thing is look at the elctric meter first, how fast its spinning, then plug it in and look at the meter again, these things WILL pull some juice, BUT like I said 4 hours plugged in usually works pretty well, unless its below zero.
Whew, the meter really does go fast when the heater is plugged in. Thanks for the advice. I will get me a timer to come on 2 to 3 hours prior to cranking it up.
Be Kind To One Another, REMEMBER: You Reap What You Sow! |
