Need a manuel for my T2000
I love my truck.but I could sure use a manuel for my 99 T2000, She has a new NS14 with a super 10 and 390 rear ends. Most of the problems we are having are little ones.Like yesterday she wouldn't start after sitting for 2 days. New batteries, altinator, so we put in a new solinoid, turned over but didn't start. More to this story but what I really need is a manuel..any one out there help me ?
You don't need a manual. There wont be anything in there to help you anyways.
What you need is a good mechanic. Is there a way to read codes on this truck? If it says anything about voltage to your ecm, that might be your problem. Check the wires on the battery, usually the ECM has its own wire running there.
If it is turning over, then you may have a fuel problem instead of electrical. I would take it to Cummins. They could probably diagnose your problem in a few minutes. You may even give them or a local KW dealer a call. They might be able to point you in a direction to solve the problem.
