over weight permits
over weight permits
how do i go about getting over weight permits? is there anything special i got to do with insurance? any restrictions? i may need the permits to go from ny to FL. this is a one time load also.
Most states will allow you to order direct, but not all. You may want to get a permist service to do it for you, at least for the first time. I usually order my own permits from those states where I can order direct. I have a service that I use for those that I don't deal with directly. If you need a permit service I can pm it to you if you let me know.
You will need ALL you dimensions including ALL axle spacings and ALL tire sizes. You request the routes and then the states looks @ the dimensions requested and compares that to restricted weight bridges, low bridges and construction zones. Most permits require a "Provision Sheet" with the permit. Read the permit AND the Provision sheet and be sure you understand everything. You may have curfews to contend with>be sure you know where county/city boundaries are.
120k-ish. they're the big cat generators. gonna use the pete IF this guy comes though. that at least has the insert.. lol i'd kill the frame of my truck.
