Visor noise in KW T660
Old 05-14-2011, 03:56 PM
Default Visor noise in KW T660
Anyone know of a fix for the extremely loud wind whisle noise you get w/ the new Kenworth T660. The other day it was so loud in a cross wind I didn't hear a med unit next to me. Thanks Chris
Old 05-14-2011, 05:19 PM
Hey, I just got a KW T660 last week too. It has that same wind noise. It was so loud in Wyoming, that I had to crank up the stereo to block it out. I am at home for a couple days and will look closer to see what it might be. I'll let you know if I find out what it is.
Old 05-14-2011, 10:40 PM
You need to have the windshield seal checked. If you use a water hose and spray up along the top of the seal, you can find out if the seal is bad quick and cheap.
Old 05-15-2011, 04:06 PM
I had another company driver tell me the same thing about the window seal.
Old 05-15-2011, 06:00 PM
Over the years, bad windshield seals have been an issue from PACCAR...Pete's or KW's. A full stream from a garden hose shows where the seal is bad.
Old 05-17-2011, 02:05 AM
Mine makes the same noise. (its a 08) But I can only hear it with the windows open... I just had my seal replaced it leaked like crazy and if I was sitting and it was raining it would pool up in the upper dash till i moved. Then it was a waterfall all over my dash, radio switches/gauges.... The windshield seal shrunk causing the water to drip down the inside of the windshield. And it was a mix of the factory xm ant and the visor lights grommet leaking in the roof.
But for the life of me i cant figure out the wind whistle.
Old 02-14-2013, 12:09 AM
What is happening through a lot of testing I found is the air ( headwind) is going across the top of the hood and the little gaps at the bottom of the windshield at the wiper arm cutouts trap air and the air runs up the void under the seal and blows out the top corners of the seal. If anyone has a gazoo noise at the windshield area, just start at the wiper arm cutouts at the bottom of the windshield and take a tube of silicone, lift the seal up a little bit and fill the void under the seal and fill it all the way up to the top corners of the windshield. The vendor who made the seal for KW made it to flexible and they are working to correct it. I have corrected this problem on hundreds of the T800, T660, and on the W900. Believe me, I have driven trucks to make this start doing this and found going west bound and hitting enough headwind will start it, I was bound and determined to find out why till I found it through compressed air blowing at diffrerant areas around the seal and made it do the same.
