6x4
The army used to have trucks that had two axles in back, and the steer axle in front, and all three were drive axles. They were referred to as 6 X 6. They also had single tires on each axle, not duals. So, for a 6 X 4, I'd expect to see 6 tires on the ground, 4 on the rear axle, and 2 on the steer axle.
YES ! ! ! There is life after trucking. a GOOD life
No, it's just your standard tractor. That's why I don't get the 6X4, it has the pictures of the trucks and they're not Tri-axles or even quads, and it's not on EVERY truck, just a few. I thought maybe it had something to do with the transmission. I look at this site religiously, truckpaper.com, and it seems this particular thing has just popped up in the last 3 or 4 months. Here's and example, sorry there isn't a picture but I haven' figured that out yet. The 6X4 thing is on ALL models, T2000, T-600, 660's, WL's, 800's, PETE'S, Frieghtliners etc., all just standard tractors. If you go to that website, truckpaper.com, and select a make and go down to the "keyword search" and type in 6X4 it will bring up just those trucks with 6X4 in the ad. This is more about curiosity than anything.
2006 KENWORTH W900L Email This Add To Trucks Of Interest Print This -------------------------------------------------------------------------------- Hide Main Picture Reset Special ZOOM Features Hide Thumbnail(s) -------------------------------------------------------------------------------- Specifications Quantity 1 Stock Number U72636 Year 2006 Manufacturer KENWORTH Model W900L Price $43,500 AEDAUDBGNBRLCADCHFCNYCZKDKKEGPEURGBPHKDHUFINRJODJP YKRWLBPLKRLTLLVLMXNMYRNOKNZDPLNRONSARSEKSGDTHBTRYT WDUSDVEBZAR Location Denver, Colorado Condition Used Sleeper Size 86" Sleeper Studio Sleeper Engine Specs Cummins Engine Type ISX Horsepower 565 Fuel Type Diesel Mileage 851,874 Transmission 13 Spd Check for Over Drive Yes Engine Brake Yes Suspension AG 380 Ratio 3.55 Tires LP24.5 Wheels All Aluminum Wheelbase 275" Number of Rear Axles Tandem Front Axle Lbs 12,000 Rear Axle Lbs 40,000 VIN 144210 Detailed Description Gross Vehicle Weight (lbs): 80000; 6x4
When I got older and started looking at retirement, I let my truck go and stopped looking at truck ads. Especially, looking at what's going on with EPA and CARB. The way regulations are coming out, how long will a guy be able to run one of those used trucks? You buy it this year, only to find out that because of new regs, it's illegal to run in half the states you run in? Why even bother?
So, I have not been seeing things like 6 X 4 in any of the ads. It would seem they've adapted that from the army 6 X 6s. But, that referred to the tires on the ground, and the number of them that were drive tires. They only had two on each axle.
I always assumed it was (# tires) x (drive tires). IE a 2 wheel drive pickup truck is a 4x2. A 4 wheel drive p/u is a 4x4. On a semi, they probably count dual tires as one. Therefore a 6x4 is your standard 10 wheel tractor with both rear axles as drives. A semi with a lift or tag axle would only be a 6x2.
The first # represents "total # of wheel-ends". Second # represents "total # of Driving wheel-ends". 6 x 4 is a typical tractor, or tandem drive truck.
Bob H |
