Air Bags
Air Bags
I have a kw t800 with 8 air bags, and gauges to monitor the pressure on the left and right side. I have noticed that the right side always has about 30 psi more air than the left side. I have measured the height of the rear frame rails and they seem to be the same height. I don’t like seeing the right side having 80 psi on the bags and the left only having 50 psi. Is this something I should address. Also when I am unloaded the left bags have no air and the right side has 30 psi.
Re: Air Bags
i agree with ptd, it has a levelling valve on each side of the chassis... replace both the gauges are easy enough to check with regulated shop air
Bob H |
