airing up tires
airing up tires
I know that this is going to be a "duh" question. My company gives us a air hose to air up our tires when on the road. How do I do this with the glad hands on the trailer ?
you have to disconnect your airline from the truck to hook up the airline to fill the tires.
She gets mad when we go to slow...so I'm beggin' you man keep a shovelin' that coal...Let's Rollll!
Re: airing up tires
http://fredogtrucking.proboards.com
Re: airing up tires
That way when you push in the red knob you have air to your hose,AND the emergency brakes are still applied on the trailer while you're doing your inflation.
Re: airing up tires
Originally Posted by Splitshifter
Actually, you should use the red one.
That way when you push in the red knob you have air to your hose,AND the emergency brakes are still applied on the trailer while you're doing your inflation. Hooking to the red line just makes sense. That's what I do. First, pull the trailer valve and dump the pressure. Next, hook up the glad hands, then push the red valve back in to supply air to the chuck. Some hissing at this connection seems inevitable, but if it's hissing a lot, try for a better seat on the seals. I find it's quite difficult to get a tight connection when neither glad hand is anchored to something solid, so I often have to jam them against my leg to try to coax that last bit of turn. Especially getting them apart afterwards. Good luck to the OP. The little blue hose can really save your ass, and save your schedule too.
Re: airing up tires
yes that's right, but the connector on the air tank is the best way, in my opinion That way when you push in the red knob you have air to your hose,AND the emergency brakes are still applied on the trailer while you're doing your inflation.
Re: airing up tires
Originally Posted by roadranger
You can get an extra 100 ft/lbs of torque if you use Harley air instead! :wink:
http://fredogtrucking.proboards.com |
