brakes
Old 09-03-2007, 07:29 PM
Default brakes
do you adjust trailer brakes at the same time when you do the truck
THANK YOU
Old 09-03-2007, 10:34 PM
You "check" them, you don't "adjust" them - unless it is a very old trailer or tractor with manual adjusters. Automatic adjusters have been standard since 1990 or so? If an automatic adjuster is out-of-adjustment it needs to be rebuilt or replaced - "adjusting" it is just masking the real problem and it will probably be out again in a couple days (or hours!) ...
Old 09-03-2007, 11:20 PM
You can adjust automatic slack adjusters but its a pointless exercise unless the adjuster isn't working or DOT is running a safety blitz and you want to make sure your brakes are "snug".
The battle may not always go to the strong nor the race to the swift but thats the way to bet
Old 09-03-2007, 11:42 PM
Kranky's Avatar
Where I work, whenever I have a truck in for PM, I'll manually adjust the brakes just to be sure that they're within spec.
And if I find one that is "way out" of adjustment, then the auto slack gets replaced.
Old 09-04-2007, 03:49 AM
Exactly
We have to check and adjust the slacks, manual or not :roll:
Of course, the way vocational trucks run through brakes, it probably isnt a bad thing lol
Old 09-04-2007, 04:43 AM
Checking and adjusting are two totally different things.
If you have automatic slacks, and you check them and they're not adjusting correctly, they get tossed.
You do NOT adjust auto slacks. If they're out of spec, there's something wrong with the system and they need to be REPLACED.
Old 09-04-2007, 07:05 AM
Not sure if this is correct but this is what I was told.
Get on a hill and roll backwards tapping the brakes to cause the trailer slack adjusters to adjust.
Step on the brake up to 90 psi application to cause the truck slack adjusters to adjust.
Is this correct?
Old 09-04-2007, 10:24 AM
Kranky's Avatar
Evidently you missed the second sentence in my post Allan:
:wink:
Old 09-04-2007, 10:27 AM
Kranky's Avatar
Is this correct?
Auto slacks adjust as necessary when the brakes are applied and released.
It makes no difference whether the truck or trailer is stationary or moving forward or backward.
The brake application in reverse thing is for 4 wheelers.
Old 09-04-2007, 04:30 PM
:wink:
Your second sentence is irrelevant, because even if it is a "bit out" it should still be replaced, and the slack should NOT be adjusted.
Reply Subscribe
