Changing batteries ?
Old 02-18-2009, 02:37 AM
Default Changing batteries ?
I have at least 1 maybe 2 batteries that need replacing. Is it best just to do all 4? Which of the batteries start truck? Is there anything to reset afterwards since there will be a temporary power shortage?
Old 02-18-2009, 02:48 AM
When I had my own truck, I would replace the ones that were going bad or getting weak, rather than replacing all four. I don't believe there are any trucks out anymore that have split-service on the batteries. But,even with that, if you have 4 batteries, and the truck is only using 2 when it is running, it will still be using all 4 when cranking.
And, as to what to reset... The clocks. Any clocks you have inside that are powered by the batteries will either reset themselves to 12:00 (digital), or stop running while the power is off. Beyond that, I have never heard of anything needing to be reset in the ECM or anything like that.
Old 02-19-2009, 06:56 PM
solo379's Avatar
How old is those batteries? Normally, I'd recommend all 4, it's safer that way....
And no, you don't need a "reset" anything, but the clock....
Old 02-19-2009, 09:16 PM
The batteries are all the same but, one of the batteries is a 2006. Not sure about the others because the stickers are gone. Gonna take them to Autozone this weekend and have them tested. The batteries are Interstate, btw.
Old 02-20-2009, 01:28 AM
heavyhaulerss's Avatar
the batteries can test good today & next month go out. I always replace all my 4 at the same time. though I'M one of those guy's who replace both wiper blades at same time also. when I park my truck I want to have as much peace of mind as possible knowing the likelyhood that my truck will start.
Old 02-20-2009, 02:20 AM
solo379's Avatar
So it's about 3 years old, and i get it's not you, who put it in service? I'd go with all 4....
Old 02-20-2009, 04:08 AM
If you don't replace them all it doesn't take long for all four to only be as strong as the weakest one you left in. Your call.
Old 02-20-2009, 05:32 PM
Maniac's Avatar
Yep, road calls usually start at around $100.00.
I change all 4 after they make it thru 3 winters, I don't care how they check out, 3 winters.......... they are GONE
Old 02-20-2009, 08:47 PM
I think it's unanimous
Old 02-21-2009, 05:54 AM
The problem is if you change only 3, and the fourth one internally shorts a week later guess what happens? It completely drains the 3 new batteries.
Completely draining batteries absolutely kills them. Even brand new ones.
Reply Subscribe
