correct idling r.p.m.
Old 02-28-2007, 07:42 PM
heavyhaulerss's Avatar
Default correct idling r.p.m.
what is the correct r.p.m.'s for a 11.1 detroit motor to idlle, when running truck overnight? is there different r.p.m's for different temps?
Old 03-01-2007, 09:13 PM
We usually set ours to run at 1000-1100 if idling for extended periods. This works well to help A/C in the Summer and also with heat in the winter. This also prevents loading a cylinder with fuel eliminating cold smoke when you gas on it. We set 12.7's and 14's the same way.
Old 03-03-2007, 02:00 PM
idling at base engine idle speed (6-750rpms) will cause cylinder liner glazing... then blow-by, the pistons have to be pulled to correct this condition
diesel engines should not fall below 165 deg f during long idle periods
pay attention to anti-idling laws. there is a free guide on;
http://www.onan.com/images/apu/f-1715.pdf
Old 03-08-2007, 10:37 PM
I boost my idle up just enough to stop the loud rattles in my old Freightshaker - about 800 RPM does it. Can't sleep at the normal idle of 600 RPM :lol: .
Old 03-08-2007, 11:51 PM
That's true-I idled mine around 8-900
