Does anyone where you can get a boost pressure gauge kit?
I wanted our shop to install the boost gauge on my truck but they told me "it'd be too expensive" and that I'd be better off buying a "kit". Called an International dealer and the guy never got back to me. Are there any sources of such gauges online somewhere? I tried searching via google but didn't find anything for heavy trucks
Watch my YouTube videos
http://www.truckpro.com/docs/parts_s...tr_index2.html
http://fredogtrucking.proboards.com Last edited by Fredog; 06-05-2009 at 12:50 AM.
What kind of boost levels do you need to monitor? Pressure is pressure. Autometer makes boost gauges up to 100psi etc for cars. They also make mechanical and electric gauges in both analog and digital displays in all kinds of styles and colours.
Electric gauges use a pressure sensor you install on the engine to take a reference signal and the gauge you install in the dash displays the boost based on the sensors output voltage. Mechanical gauges use air pressure to move the needle in the gauge and have a boost pressurized line running from the engine to the dash. I like mechanical boost gauges in my turbo gasoline cars but in a diesel truck that spends a lot of time in boost I would use an electric boost gauge as mechanical gauges can go out of adjustment with sustained high levels of boost. here are some of the many gauges Autometer makes in 0-60 psi. Auto Meter Auto Meter Auto Meter Auto Meter Auto Meter Auto Meter Auto Meter Auto Meter Auto Meter Auto Meter Auto Meter Auto Meter Auto Meter Some have different lighting options etc find the style you want then buy from ebay or summit racing using the autometer part number. EDIT, your from guelph so buying from Summit or ebay might leave you with border charges ordering from the US. Try a local retailer in Guelph like Performance Speed & Sport etc Last edited by FunkRider; 06-06-2009 at 09:23 PM.
My KW has a mechanical boost gauge from the factory, it goes to 80 PSI, if you have twin turbos you will need a higher boost gauge than I have, since I have a single turbo. I uses a 1/4" plastic air brake line rated at 200 PSI to the intakes side.
In a hard pull I can pin the gauge, but it usually is around 60 PSI
My KW has a mechanical boost gauge from the factory, it goes to 80 PSI, if you have twin turbos you will need a higher boost gauge than I have, since I have a single turbo. I uses a 1/4" plastic air brake line rated at 200 PSI to the intakes side. In a hard pull I can pin the gauge, but it usually is around 60 PSI
A boost gauge is just an air gauge so any air gauge should work. You know, like your brake application gauge. You should be able to get one for free or near to it at any wreckers or somewhere they're are parting out an old truck.
And like I said autometer has boost gauges that read up to 100 psi.
Mechanical gauges use air pressure to move the needle in the gauge and have a boost pressurized line running from the engine to the dash. ... your from guelph so buying from Summit or ebay might leave you with border charges ordering from the US. Try a local retailer in Guelph like Performance Speed & Sport etc
Local place I know has mechanical gauges pretty cheap and accurate. You could hook it up for $40 probably. Not an actual dash gauge though. More like something off of an air compressor.
