engine speed related vibrations
Old 05-04-2009, 02:47 AM
Default engine speed related vibrations
i could feel a vibration on my cummins isx 500 @ 1300-1450 rpm (978K miles). i know it's not my drivetrain. i would put it in neutral and rev it up to around 1300-1450 and could feel the vibration, kind of like when the driveshaft needs balancing.
anyone know what the cause could be? any advice would greatly be appreciated....
Old 05-04-2009, 10:19 AM
Kranky's Avatar
At that mileage there's a good chance that the harmonic balancer (also sometimes called the vibration damper) needs to be replaced with a new one.
If that's the case, then get it taken care of soon, as that vibration can eventually cause a broken crankshaft.
Old 05-07-2009, 04:07 AM
Smile
I second the harmonic balancer... I replaced mine from Pittsburg diesel. Check out their website and scroll halfway down for it.
The Pittsburgh Power N-14E Cummins and 3406E Cat Electronic Upgrade Kit
:bow:
Old 05-11-2009, 02:28 PM
Bandit102's Avatar
Yes, definately get that balancer checked out. You could end up with a busted crankshaft and thats some MAJOR bucks.
Old 05-14-2009, 11:05 PM
I experienced this on my way from Chicago to Cincinnati today at around 70 mph, I'll check that out, although my mileage is alot lower then his.
Old 05-23-2009, 08:58 PM
In neutral? ...and it does the same with the clutch pedal depressed and at the same speed?
You're SURE it's not misfiring at that speed?
