Fuel Filters
Fuel Filters
Exactly what are the ramifications of having dirty fuel filters. I have a CAT ACERT engine. I was low on fuel and my engine died. I thought maybe there wasn't enough fuel in the tanks to make it to the engine. I happened to break down on the highway in front of another driver's house. He came out to help. We ended up changing the filter/water separator and the fuel filter, both were dirty. Once we got them changed and primed the engine ran. A couple of other symptoms I've noticed are when idling sometimes there is a miss in the engine and no mater what I do my fuel mileage has been dropping. TMC has us put the truck in the shop every 25,000 miles. I suspect the shop isn't doing the proper maintenance.
Were the dirty filters causing my fuel milage to decrease?
Terry L. Davis O/O with own authority
Got a see-thru filter? As the filter gets dirty, the fuel level will rise. When it gets near the top, it needs to e changed.
your engine likely shut down due to fuel starvation (i ran outta gas ?!?)
it didn't re-start because the fuel system was aerated (stand of supply fuel was displaced by air) it then started after replacing the filters because the new filters were filled and the fuel system was primed (air purged from fuel system). most diesels are very difficult to re-start after the fuel system has been run dry ... some of course more than others ........ cat ... mbe ? it's funny how the fuel filter restriction is always blamed despite the fact that the engine had no power complaints leading up to the shut-down... hmmmmm
Well, the first sign it was out of fuel, was that the engine shut down. Out of fuel as in the engine wasn't getting fuel. There was fuel in the tanks. Whether it was being sent to the engine is another question. Once both filters were replaced, and they were dirty. Priming them was as simple as filling the filter with diesel before it was installed and filling the water seperator with fuel through the small cap at the top. The engine ran fine after they were changed. Far beyond the fuel that primed them. Perhaps there wasn't enough fuel in the tanks and it began to suck air and the engine stopped. I don't know, why would it then run afterward just fine? I'm not a mechanic and I don't play one on TV.
Because it will slowly suck in air. Until it gets to a point where it can't suck in any more fuel. Fuel pumps can't pump air very well, as we all know.
Do an experiment, run your tanks low. If it does it again, it might be in the pickup tube. If it just does it randomly, it's further down the line. Look at the fuel filter bosses, probably the first one. That's where I had my problem. To test your system, plug one tank vent tube, and put a *small* amount of air pressure into the other side and seal it. Start from the back, work your way to the front. If you find bubbles, you just found the problem. Could just be that the previous filters weren't tight. That's happened more then once.
I seemed to have fixed the problem. Maybe it is still too early to tell. I was asking if dirty, clogged filters would cause the engine to die, probably so, and if it is causing poor fuel milage.
Terry L. Davis O/O with own authority |
