Help!!!
Help!!!
Hey guys I have a 2002 Volvo VN664 with a 60 series Detroit with a Eaton Fuller Autoshift transmission I bought it about a month ago and was planning to put it on the road Jan 1st
Well I got up this morning and it wouldn't start.....Nothing All the interior light work..... the starter does not engage The auto shift "Box" is not getting any power with the key on. I've checked the fuse box and everything seems fine Would really apreaciate your help.....Chris
hey chris, sorry you're having problems. i've never been around a volvo, but here are some things i check if my freightliner doesn't start.
1) i check to see if the headlights will come on. if not, or if they're weak, it's usually a battery/voltage issue. when this is the problem, they truck will also make a "clicking" sound when i try to start it. 2) if the headlights come on, and the voltage is good, then i check the starter. sometimes the wires are loose, etc. make sure everything is tight and making a good connection. sometimes, if the starter is older and starting to wear out, you knock the crap out of it with a metal hammer or something and the gears will move a little and you can then start it. 3) on a lot of freightliners, there is a relay, or solenoid on the firewall that transfers the electrical signal to the starter from the cab. they often wear out, fail ... check it with a test light, that its firing "hot" when you try to start the truck. 4) there's also a fuse, in the wire that brings "fire" to the truck ecm, check to make sure that is good. 5) freightliners have push button ignition, the button wears out, they key switch wears out, check that when the key is turn, the button is firing hot. thats all i can think of, hope it helps you.
RE Help!!!
Thanks for the help guys... The batterery is fully charged, the starter
does not even click when I turn the key. I'll try to tap the starter to see if that works. The thing that bothers me is that the autoshift box is not lit up. I was wondering if there was a fuse that controls the autoshift box Thanx Chris
The autoshift ecm has its own wires running to the batteries. If you've got a bad wire there or a bad harness at the tranny you'd have a power issue. If the tranny isn't sensing that the clutch is engaged, it won't let the truck start but you should still see the display power on when you turn the key. The fact that you're not getting power to the display should make it easy to find...somewhere between the battery and the tranny ecm :lol: I hate electrical problems.
a quick way to check the tranny ecm is to stand next to the truck and turn the key on you should hear the tranny shifter clicking (it's making sure the tranny is in neutral) before it will let it start. and like no_worries said check the tranny wires at the batteries. (should be small white wires) you may need to unhook the batteries (10 min)to get the tranny ecm to reset.
it's a quirk with the auto-shift in 4 years and 7 trucks i've had to do it 2 times and had the white wire come loose once.
I really don't know a lot about this but around your fuse box should be little boxes about 1" by 1". These are relay switches that engage things that require lots of power like your horn, lights and starter. I would try unplugging them and putting them back in. You could also locate the one that is used for the starter, pull it out and put the headlight one in there. Now see if the auto shifter is powered up. Don't try and start the truck though until you replace the starter relay with the proper sized one.
