High pitched turbo noise..
Old 03-30-2008, 11:47 AM
Kranky's Avatar
Could be a very slight leak at a clamped connection between the turbo and the intake manifold.
This would include all the connections at the turbo, CAC, and intake manifold.
Check the CAC for cracks near the header especially on the hot (turbo) side.
Could be an intake manifold gasket.
Also check the air line that feeds the air compressor with turbocharged air.
I've seen instances where a miniscule leak in any of those places can cause a "whistle" or "whining" sound which rises and falls along with the turbo whine. Not enough of a leak to affect the boost pressure or engine output, but enough to make noise.
Old 03-30-2008, 12:20 PM
countryhorseman's Avatar
Possible guess, Series 60 Detroit - FLD or Columbia!
They all do it! The '06 I drive sounds like a jet fighter at times. Something to do with the Turbo design, wastegate and the emission stuff! Can be quite annoying when trying to sleep.
Sound asleep, and it winds up for take-off! Ugghhhh! :sad:
"I discover the principles that work and work them,
I am forever learning new principles that interaccomodate with what I already know, to the betterment of my life and my world.
As principles are revealed to me, I cheerfully record them, use them, and share them.
Principles are, without question, the fastest way to what I want."
Author Unknown
OOIDA
Old 04-07-2008, 02:40 AM
Bandit102's Avatar
Whistling turbos and long hoods are cool...until bedtime and fueltime.
Old 04-14-2008, 12:09 AM
Walking Eagle's Avatar
Location: In my own little world, that rides right behind the cab.
Just put a Variable Vane turbo on my Cat. If you want noise that SOB will give it ti ya. Riding along it is fine but start wanting real power and you have to wind the windows up or put in ear plugs :sad: Good for running off deer though
