How to remove fridge
Old 09-07-2007, 06:37 AM
Default How to remove fridge
Does anyone know how the fridge is kept in place. I can't find any screws holding it in and not sure how to get it out.
Old 09-08-2007, 12:47 AM
Try to look inside the surrounding cabinets, sometimes they hide the screws there. If the unit is on a shelf (not on the floor) there could be some screws there from the bottom. Mine is easy, 4 screws on the front, and pull it out of its socket.
Old 09-08-2007, 02:48 AM
silvan's Avatar
Take a bigass crowbar to it. When you rip it out, you'll be able to tell where the screws were, by the stretched metal.
Old 09-08-2007, 03:39 AM
Maniac's Avatar
Along the sides of the fridge where the door is you will see 4 little black rubber plugs, pry them out, the screws are BEHIND them.
At least thats how it is in my KW
Old 09-08-2007, 04:09 AM
Part Time Dweller's Avatar
Some have a plastic trim piece that is velcroed on. Pull that off and the screws are behind it. That is the way it was in my '01 387.
BTW, if it is a Norcold, you can get parts for it at any larger RV dealer cheaper than the truck dealer. Providing that is why you want to take it out.
Old 09-08-2007, 06:03 AM
Thanks for the tips, I like the crowbar approach myself and will most likely take that route when I get pissed off enough.
Believe me, I've looked every place and no trace of anything holding it in. The only thing I can think of is the black metal trim peice around the front but that seems to be a permanant part of the fridge.
Old 09-08-2007, 11:52 AM
Dynamite works better, it' faster and leaves a nice big space so you can install a bigger one.. have you called a dealer and asked them how to get it out?
Old 09-08-2007, 01:29 PM
I've called 3 dealers and none of them know anything about them!
Old 09-08-2007, 06:19 PM
WOW!! how about getting the brand name of the unit and maybe try the manufacturer?
Old 09-08-2007, 07:19 PM
The manufacturer will not have a clue, they just make them. I'll just wait until I'm down in Laredo. There's a truck fridge place there and I'll let them deal with it. Thanks for the tips guys.
Reply Subscribe
