leveler
Old 05-28-2007, 04:03 PM
Default leveler
does any one know where i should ajust my leveler to on a 96 volvo daycab? thanks
Old 05-31-2007, 04:34 AM
Dual axle?
The leveler is on your front axle, drivers side. It's a PITA to get under and adjust, but it's worth it.
What is the problem? Why do you want to adjust it?
You can get the proper spec for ride height from volvo, as well as instructions on how to properly adjust it. If it's too high or too low you can screw up the driveline angles, and that's a major problem.
Do you get driveline vibrations?
Old 06-01-2007, 12:12 AM
no this is on the drive axel, it ajusts the air in the air bags. thanks for the info, im going to call volvo and see if they can give me some specs.
Old 06-01-2007, 12:21 AM
Yeah I meant the front axle of the drive axles, sorry for the confusion.
