MOTORKOTE
Old 01-08-2008, 06:33 PM
marcel27208's Avatar
Default MOTORKOTE
has anyone ever used this product(motorkote)......... its about 70 bucks a gallon, i seen it at a steel city truck stop somewhere in indiana.........
yeah im back
Old 01-08-2008, 09:14 PM
junk
don't bother
Chlorinated parraffin. In other words, it breaks down under normal engine operating temps and can be harmful to your engine.
Old 01-09-2008, 02:36 AM
snake oil
Old 01-17-2008, 12:51 PM
Copperhead's Avatar
I agree.... not worth the money.
Look... motor oils today are pretty darn good, especially the higher end synthetics. Stick with them, do good oil analysis and pms and you will keep cost effective and get good protection.
See the discussions on the forums and the testing that has been done at www.bobistheoilguy.com
Most addtives are not worth the money and may actually cause a problem.
Old 02-22-2009, 09:22 PM
I own a small trucking co. and have been using motorkote in all my trucks for 6 years. Three of my n-14’s have over 1 mil. miles on them and the rods & maines were replaced at 900 thousand miles.
I had a driver climbing westbound out of Albuquerque in the summer when he lost his turbo. In all of his wisdom the driver decided to restart the engine at which time the engine started to use the oil as fuel and the engine did not stop running till all the oil was depleted. Long story short the only damage to the engine was a new turbo and charge air cooler this was two years ago the engine is fine. I swear by MotorKote!!!!
It is also cheaper to run than lucas. 30$ per every four oilchanges. I also run it in the Trans.,Diffs.,and Steering.
Old 02-23-2009, 02:18 AM
solo379's Avatar
Thumbs down
Sounds like commercial...
Old 02-23-2009, 02:29 PM
when i seen post i was about to say i asked about that stuff about a year ago................1 positive response....a year later
Old 02-25-2009, 03:54 AM
Copperhead's Avatar
Having high miles on an engine is not a valid endorsement of MotorKote. I put 1.4 millions miles on a previous N-14 and NEVER had the rods or mains done in that time, never lost a turbo or had anything more than injectors replaced. I only used Kendall 15w40 oil and Baldwin filters. It still was not using any more than 1 gallon every 10K miles and getting near 7 mpg when I got out of it. It wasn't my truck, or else I would have kept it.
The oil producers have put a lot of research into the additive packages they put in their oils. I am pretty sure that the over the counter oil additives are totally unnecessary. In fact, some of these additives will conflict with the additive package in some oils and do more harm than good. Why bother? If you are wanting to spend money on something, then spend it on oil analysis kits from a reputable lab and sample your oil and see how it is doing and how your engine is holding up. You will get more bang for your buck doing that.
Old 02-25-2009, 10:38 AM
Kranky's Avatar
X2:clap::thumbsup::smokin:
Old 02-27-2009, 09:50 PM
Maniac's Avatar
Oil additives...........snake oil
Read it here
Car maintenance bibles: Oil Additives
If you really feel the need to use some additive send ME whatever $$$ you think its worth and I'll send you a bottle of something you can put in.
