My Pete 362 is making me blue
So I go out to start up my '94 Pete cabover and as soon as I turn the key to the start position-NOTHING! No low air warning buzzer, no dash lights, no accessories, nothing. It's like the cab has no electrical power at all. The interior light came on for a few seconds and then faded out never to come back on again. I thought it was the batteries so I tried to jump it to no avail. I pulled all four batteries and tested them and they all read fully charged. The battery posts and connections are all clean. So this leads me to believe that a connection is loose or maybe a main fuse is bad. Am I on the right track? This truck has started religiously no matter how cold for as long as I've owned it (about a year and a half) and has been bullet proof reliable until now. Anyone have any ideas? Thanks.
Yeah, I would check the ground.
If not that, it might be the mother board. The grandmother of them all that runs the whole kit kaboodle. :hellno:
From your discription, (no accessories) just seems most likely ground strap to the frame. Next suspect for me would be the starter switch, then main fuse.
Is there a battery cutoff switch?
