Over-sensitive steering
I know a few people brought up steering problems but I'm at a loss with my 2004 International 9400. It drives great on a perfectly straight road, but as soon as the road surface tilts (like when you're in a curb lane), the truck just steers itself in the direction of the tilt. Most of the time when I'm in the curb lane I have to keep my steering wheel turned to the left. If I take my hands off, the steering wheel returns to the central position and the truck starts drifting towards the ditch.
"Your alignment is perfect", I was told more than once by technicians in various Ontario, Canada shops. I did all the axles twice, plus had caster adjusted on top of that... all to no avail. The tires are fairly new (installed them in June 2007), and I just had the truck thoroughly checked out for wear and tear in kingpins, tie rods, and improper tightening of wheel bearings. I was also told the steering box had defects. What can cause this over-sentivity of the steering? I personally tend to think it's either the steering box or the wrong size tires (the original tires were low profile 295s; and now I have larger diameter 22.5). I called a couple of shops for a quote on a steering box and it's 700 bucks minimum with the exchange.... plus labor. Do you guys think replacing the gear box can help make the steering normal again or would it be just a waste of money? The truck has only 219,000 miles and the steering box is Sheppard M100. Thanks!
Watch my YouTube videos
Re: Over-sensitive steering
sounds normal to me. the weight of the truck is just following where gravity is pulling. and in this case its going down towards the curb. you should only test the alignment on a straight, FLAT and LEVEL roadway.
Originally Posted by God Almighty
Go drive like a Christian or a Texan!!!!
Originally Posted by COLT
Why do you think this is abnormal ?
Originally Posted by nickbtubas
... sounds normal to me. the weight of the truck is just following where gravity is pulling
Originally Posted by allan5oh
It's possible your steering box is adjusted too loose. Is there a lot of free play in the steering shaft?
How does the truck do in ruts?
What do you mean "the steering box had defects" ? If the pitman arm is moving up and down you'll have wandering issues. How much caster are you running? usually the more caster you have the less the truck wants to wander. You can run engine oil in the steering box. I know when I went to 15w40 from ATF the steering effort went up and it seemed to tighten up the steering a tad. Some trucks are more apt to do this than others. My T-600 did the same as your's. Sometimes the movement comes from the rear suspension moving around. My Pete with the Air Trac doesn't ride as good as the 8-bag but it also doesn't wander or head for the ditch on a high crowned road. Good luck.
Sorry, I made a mistake. It should have read, "... the steering box had no defects". Thanks for the tip about the arms. I'll have them checked.
Watch my YouTube videos |
