Possibly water in fuel??
Truck has been running great...all of a sudden I notice that it's lacking some power and idling really rough. Just a sudden thing..didn't happen over time. So I took the fuel filter off and poured some Liquid Muscle into another fuel filter and put it back on. I didn't have any diesel to put into the filter. Been about 4 hours now and it's still idling pretty rough...the truck stop I got my fuel at has been known to have water at times, and I got fuel there twice today. So...wondering if it'ts probably water in it making it idle that rough or possibly something else? I dont have any check engine lights on or anything, just vibrating and idling rough. I also poured some FPTF stuff in the tanks that's supposed to remove water. Wondering how long it takes water to get out of the system....
Also, can you overuse fuel additives? I put fuel additives in my truck regulary. Will this cause any problems? 3406 E model CAT.
Carefuly check the exhaust manifold temp right at the head for each cylinder, if one is cooler you may have a nmisfiring injector from water, fuel additive or both.
You can't fix stupid......
Well, I found the problem. Injector #5 was bad. Apparently the rocker shaft broke off and went down into the engine?? At first they said I would need a new camshaft, but it's not damaged. I just need 2 valve bridges, 3 rocker levers and the injector....fun fun!!!!
Thanks for the help!!
Thanks for the help!! |
