restart procedure
Old 12-11-2008, 10:39 PM
Default restart procedure
I let someone use my truck and they ran out of fuel. Put fuel in and won't start. I didn't want to keep cranking it and drain the batteries. I there a procedure to restart? It's a S-60 engine.
Old 12-11-2008, 11:02 PM
Pull off the fuel filter and refill it. There may be a hand pump, and places to "crack" open the fuel lines. Call a detroit shop.
Old 12-12-2008, 12:32 AM
marylandkw's Avatar
X2
There is not a way around it either. No amount of cranking will do anything other than destroy your starter. If this is beyond what you can or will do, it should only take a good roadside mechanic 10 minutes or so to get you going again.
I am ashamed to admit that if you had a Cat I would be able to detail the procedure step by painful step from way too much experience.
Old 12-12-2008, 12:36 AM
as would I, if you had a Volvo.
Old 12-12-2008, 02:24 AM
cdn
cdn is offline
electric fuel pump plumed into the feul line just before the mechanical fuel pump turn pump on wait about 2 mins for fuel pump to pressure up and start engine, run for about a min or so then disconnect the electric pump and rehook the line from the tank nack up to the mechanical fuel pump, has worked for us for yrs when ever a detroit has run out of fuel.
Old 12-12-2008, 02:47 AM
Thanks for the input. Glad I didn't keep cranking it. It has a Davco filter. Looks like there is a cap that comes off the top to fill it. Davco says this is the procedure when you first install a Davco.
Old 12-12-2008, 03:07 AM
That probably won't fix it. You need to purge the air.
Old 12-13-2008, 02:47 AM
I put fuel into the filter and it started after a few cranks. Thanks for all your help.
Old 12-13-2008, 03:21 AM
You got lucky!
Usually when it's completely bone dry, just filling the filter won't do anything, as the pump cannot suck it up anyways.
I'm willing to bet it wasn't completely dry.
Old 12-20-2008, 07:52 AM
You were lucky mate. I run one dry in a K104 several years ago and it was a major PITA!!! We needed an electric fuel pump to pressure diesiel through the fuel lines and if memory serves there were two bleeders that had to be opened to get the fuel right through the system. It definitely wasnt a 2 minute job. First sign that the sucker is about to run out just pull over and shut down ASAFP!!
Just because yer paranoid doesnt mean their not out ta get ya!!
Reply Subscribe
