Should I keep it in 1st?
Question about my street sweeper (automatic transmission)
Because I spend hours on end traveling at under 5 mph, would it be any better on the engine or transmission to keep the shifter at 1st gear (even though it never shifts into 2nd anyway at that speed), or will it not make a difference whatsoever?
Re: Should I keep it in 1st?
Because I spend hours on end traveling at under 5 mph, would it be any better on the engine or transmission to keep the shifter at 1st gear (even though it never shifts into 2nd anyway at that speed), or will it not make a difference whatsoever? if it never shifts, then it's not a problem ... i would just leave it in drive if it were upshifting/downshifting all of the time; that would be a problem ... then you might want to keep it in 1st
Bob H |
