starter problems
I had to rebuild one of my starters this summer. It was much cheaper than buying a new starter. Replacing it while home will be much cheaper than being forced to do it out of town.
I had a starter rebuilt by a local top notch shop that only does alt, starters, e.t.c. for $55.00. put it in my side pocket.
Making sure that your battery is fully charge is very important and that fact that you need to have a complete tool to fix it ,but for me it is better if you go this problem to expert cause some if you don't know that problem it will cause another problem ,just like an bearing or laakeri that i used to replace where i thought its fine but when i use it there is another problem.
