Steering gear
Steering gear
I had a frightliner with a ross steering geare and was able to adjust the slack in the steering wheel. Now have Kenworth with a trw steering box and tried to adjust the slack and all it dose is make it harder to steer. the slack is still there. I had to try a happen medium so it was not to tight and had a little less slack. My question It feels like its harder to steer than it should be. is there a pressure adjustment to increase hyd pressure to the steering box, or maybe this one is just worn out??? it's really a pain in town when you have to wait till the last second to start your turn and really need to move the steering wheel in a hurry. It's so bad I even thought about one of those steerling balls, but I heard there illeagle in some states.
allan I grab the steering wheel shaft and it has a lot of free play before the draglink starts to move at all. No noise real clean fluid I have not looked for a filter not sure where it is. on my farm tractor it is in the resvoir that is mounted on the pump itself.
I may have wear in other compents of the steering system, but right now I Know there is to much slak in the steering gear. I can rotate the input shaft 20 degrees of roataion and not get any movement in the output shaft that is connected to the draglink.
There is usually a "pinch bolt" to keep the yoke tight on the spline, and I have seen many of these loosen up, and then you have "free play" in the steering. If that is the case, the splines on the input shaft and yoke could be damaged if it has been run loose for any length of time. It's a very unsafe condition, if this is indeed the problem fix it immediately.
If that is the case, look into a re-man steering box. Here is a link to the TRW site explaining the proper way to adjust the sector shaft. This is a PDf file. http://trucksteering.trwauto.com/files/PRC-SCTR.pdf My take on this is this adjustment is not intended to remove slop, but to set the box initially. |
