THERMO KING UNIT ALARM CODES
This list is ordered by SEVERITY and numerically.
TAKE IMMEDIATE ACTION: 09--High Evaporator Temp > Unit Shut Down To prevent damage, repair immediately 10--High Discharge Pressure > Unit Shut Down To prevent damage, clear and restart, if reoccurs repair immediately 12--Sensor Shutdown > Unit Shut Down to prevent damage, repair immediately 17--Engine Failed to crank >Clear Alarm, preform manual start in continuous mode, repair as required 18--High Engine Water Temp > Check belts and coolant level, correct 19-- Low Engine Oil Pressure >Check oil level, correct, clear alarm, repair as required 20--Engine Failed to Start > Check fuel level, preform manual start in (Cycle Sentry) continuous mode, repair as required 23--Cooling Cycle Fault > Unit shut down to prevent damage, repair immediately 24--Heating Cycle Fault > Unit shut down to prevent damage, repair immediately 25--Alternator Check > Press "Amps" to check alternator charging rate, repair as required 30--Damper Stuck Closed > Damper is Stuck closed, repair immediately 32--Refrigeration Capacity Low >Repair immediately if leak is accessible, Off load a.s.a.p./ refill freon temporary until off loaded. 35--Run Relay Circuit > Check emergency switch position if present, repair as required 36--Electric Motor Failed to run >Check standby source of power, correct immediately 38--Electric Phase Reversed > Standby power phased wrong, correct immediately 44--Fuel System check > check fuel level in fuel tank, add as required , clear code, prime, restart 47--Remote sensor shutdown > multi-temp zone sensor failed, zone shut down , monitor temp & repair as required 48--Check Belts or Clutch > Drive belts or clutch slipping, repair as required 60--Boost Circuit > Unit operating without boost capacitors, repair as required 62--Ampmeter Out of Cal Range>ampmeter inaccurate, repair as required 63--Engine Stop-Reason Unknown>Check fuel tank level, try manual start, repair as required 66--Low Engine Oil level >check engine oil level, add as needed 74--Computer reverted to default settings> Unit has reset, control temp may not be as required, check, repair before reloading. 75--Computer RAM >computer defective, repair before loading 76--computer EPROM >computer defective, repair before loading 77--computer EPROM checksum >computer defective, repair before loading 78--Data Log EPROM >computer defective, repair before loading 82--High Compressor Temp shutdown>compressor shutdown to prevent damage, repair as required 111--Computer not Configured Correctly>computer not configured for this unit type, repair as required before loading 114--Multiple Critical Alarms, Can not run> check & note all codes, repair as required. __________________________________________________ __________
The only problem is you will get 23 ALOT when hauling Ice Cream across the desert in the middle of the summer. When it is 120 outside and you need -20 in the trailer no unit made will get it there and the unit will scream 23 at you all the time. Reset it and move on.
