trailer tires larger than tractor tires
Old 01-27-2007, 02:47 PM
Default trailer tires larger than tractor tires
I'm looking at a trailer to buy that roll on tires that are 24.5, my tractor tires will be be 22.5. Will the difference in size present any problems?
Old 01-27-2007, 02:59 PM
solo379's Avatar
The only problem, i can see, is that you won't be able to put your partially worn steers on a trailer.
Otherwise it doesn't matter!
Old 01-27-2007, 04:08 PM
and if you carry a spare, it will wont fit both.
Old 01-27-2007, 09:07 PM
You could always switch your trailer down to 22.5 also that would lower the height also. That way you could also use your old steers on the trailer. A 22.5 carries the same weight as a 24.5 so no penalty there plus a 22.5 tire an wheel assembly is about 100 lbs lighter per side less steel and rubber so more cargo room.
Old 01-30-2007, 01:45 AM
There's good news- With bigger tires on yout trailer, your rig will always be heading downhill!! That's gotta' help your fuel mileage...
Trucking is the worst #@%?>&# business you ever saw. I just wish I didn't like it so much...
