truck doesnt idle well
Ok i just had a inframe dome on a 2001 freightliner witha 475 isx. I idles very ruff, and seems to have weird vibrations around 60. my oil pressure is only about 30psi.
Re: truck doesnt idle well
Why, is 30 low? What is it normally?
Isx-475 running rough
Has it been running rough sense you got it back or did it start sometime after you got it back ?
Sounds like a bad metering or timing actuator (possibly?) If the engine runs on after it is shout off it could possibly be an injector check ball not seating = you will need a new injector to fix that. Was this "Rebuild" done at a Cummings dealer OR distributor ?? === eather way you should take it back and have that Tec. check it out.
Re: Isx-475 running rough
Diesel Nut wrote:
Has it been running rough sense you got it back or did it start sometime after you got it back ? Sounds like a bad metering or timing actuator (possibly?) If the engine runs on after it is shout off it could possibly be an injector check ball not seating = you will need a new injector to fix that. Was this "Rebuild" done at a Cummings dealer OR distributor ?? === eather way you should take it back and have that Tec. check it out. Cummings??? _________________ Bob H SORRY Bob, I had a couple of beer and mistakenly put a "g" in Cummins. My apologies to eveyone, Diesel Nut. |
