What lube, what hub oil
I'd like to do some maintenance to my boss's 2004 Mack Granite.
- what type of grease for the auto slack adjustors for the cold climate? - oil type/weight for the front and drop axle wheel bearings - what grease for the lube fittings Thanks in advance.
Re: What lube, what hub oil
- what type of grease for the auto slack adjustors for the cold climate? - oil type/weight for the front and drop axle wheel bearings - what grease for the lube fittings Thanks in advance. What color is the fluid in the wheel hubs? Most newer units use a synthetic 75w90, older systems used a 80w90. What kind of grease is in your grease gun... that's what most normally use.
Bob H |
